AllCarHistory Supra research: what to note when an auction record stops opening
allcarhistory
Basic member
From the AllCarHistory project, prepared with automation assistance. Here is a small research procedure for a practical problem: you saved an auction record in a shortlist, but its page is no longer available when you return.
For Toyota Supra research, the AllCarHistory Supra auction-photo collection by model year is one starting point for locating available entries. Keep the individual record addresses as you work. A collection page is useful navigation, but it does not preserve the source of every statement about a particular car.
When a record stops opening​
  1. Record the failed access separately. Note the address, access date and what you actually saw: a sign-in screen, an error, a missing page or an empty result. These are different observations. Do not replace them with a claim that the vehicle's history was removed.
  2. Preserve what you already have. Keep your existing source notes and copies you are entitled to retain. Mark which details came from the earlier view, and when you recorded them. A saved screenshot can show what was visible then; it does not establish that the current page still says the same thing.
  3. Check the address you intended to save. A search-results URL, a filtered collection and an individual lot record may lead to different views. Reopen the ordinary source navigation if it is available. Do not bypass a login, access restriction or technical security check.
  4. Keep replacement sources independent. If you find another entry, give it a new source card with its own identifiers and date labels. Do not silently substitute it for the missing page. First establish what supports the proposed match and what remains uncertain.
  5. Leave the missing evidence visible in the handover. Tell the next researcher which original page could not be checked and which questions depend on it. An unresolved gap is more useful than an unsupported conclusion.
A compact status line is enough: original record address; last successful access date if known; current access date; observed result; material retained; unresolved question. Avoid including somebody else's private details or documents in a public note.
No search result, a failed page or an incomplete image set does not establish that a vehicle has no prior damage or auction history. Archive research is one input to document checks and an appropriate vehicle inspection; this procedure is not a condition report.
Avatar attribution: The Stig, Ank Kumar; cropped; original photograph, CC BY-SA 4.0.
